Transmission line track width calculation
mohana_s14
Junior Member level 1
how to calculate the trace width for 80 meter distance transmission line. I am using rs 485 ic, and we split the pcb and join it using board to board connector. Single pcb length is 560mm, total length is 80 meter. Shall i route differential pair routing for AB line.
Just found **broken link removed**, may be that helps...
saturn pcb tool kit is appropriate for this
