ivlsi
Advanced Member level 3
Hi All,
As far as I know, an impedance over the whole transmission line should be constant and usually should match 50Ohm.
How could it be achieved? An impedance depends on the conductor length. So, as far as the signal propagates over the transmission line, it should "see" a different impedance since it "see" a different length of the transmission line ahead.
Could anyone explain how the propagated signal "see" the same impedance over the whole length of the transmission line?
Thank you!
Thank you!
