Transistor for a wideband LNA design is unstable!
kella
Member level 3
Member level 3
transistor stability
hello Friends
I am trying design wideband LNA and the transistor which I am using is unstable and when I am making it stable the transistor s-parameters are also chaning with stability.
Kindly suggest me your views and guide me if I am doing some thing wrong.
regards
Re: transistor stability
You will find a good tutorial here:
what do you mean by 'the transistor bocome unstable'?
Is it the current or what? 8O
u can use ads -s parameter-stability circle
