Transistor based VCO design!!
bt87
Junior Member level 3
Can anybody give me the design of VCO which can generate frequencies of 925-970MHZ & 1805-1880 MHz
please give circuit which are tested(more preferable)......
Thanks in advance.
Refer to this book: **broken link removed**
ok man...let me see this one...
thanks for help..
search dual band vco in ieeexplore.... you will find many results
I should point out the obvious, that the 2nd frequency band is roughly double the first one.
You could make one higherband vco, and divide by 2. Conversely, you could make the lower band vco, and double its frequency.
