ZappHappy
Junior Member level 1
I'm using a classic TIA configuration to measure leakage current through coax insulation in the 200nA range.
The circuit works well using a V source and resistor to calibrate but when I connect the long, high capacitance cable the noise is terrible.
Can I bandwidth limit the op amp to say 1-2Hz using a large capacitance across Rf (1 Megohm) or am I having issues due to large cap (>10,000pF) at input ?
I'm not sure if the "noise" is from the coax acting as an antenna or some other op amp stability issue.
