Disha Karnataki
Full Member level 5
if at all i have a transfromer with the ferromagnetic core it's always stated that we need to connect the primary of the transfromer to ac source than we get at secondary either stepped up/stepped down ac.
now,suppose if i apply dc at the primary the the core is said to be saturating and will soon damage itself if at all kept in the same condition for some time i really don't follow this. So what if the core saturates?? only thing is if at all the core saturates then it will be like the primary has no more opposition for it's back emf from secondary or the core's flux which used to be produced at the primary when ac used to flow That's it & hence the turns at primary will now be like wire or may be short circuit.
if i am not right then explain with your points
