neazoi
Advanced Member level 6
Hello,
I have a transformer with a lot turns primary and a low turns secondary. I need to find a way to cancel out transformer action from the secondary to the primary, i.e. if AC is fed to the secondary it should not affect the primary.
The book I am reading states a split winding secondary (center tapped?), with the two windings wound in the opposite direction to cancel out their fields in the core.
I would like to ask how should I make these windings?
1. A center tapped secondary? Imagine it like a single winding, with a tap in the center.
OR
2. Wind the first winding right hand side. When its end comes, start wind the second winding in opposite direction
Which of the two are correct?
OR
