dot4
Member level 1
Hello,
I am selecting a transformer and I found several that would suit my application. But I have a difficulty to understand the datasheet (it is attached). Why is the primary voltage given in a range? I want to use it for lower secondary voltage than stated in the datasheet (hundreds of milivolts) and I need to know the conversion ratio.
Thanks for advice.
Thanks for advice.
