Transformer Design Specifications
adityaateda
Newbie level 1
Newbie level 1
Hello,
The attached document contains the Transformer Design specifications which I have given to Manufacturer.
Do I need to provide any other data or is this data sufficient for manufacturer?
Please guide.
  • Transformer.pdf
This data is more than enough, no need of given full data, you can give electrical test specification and mechanical dimension to manufactures, they will select nearest value transformer from their product list. You can also search nearest value transformer from google,
https://www.precision-inc.com/documents/019_4967_00R_P1_Spec.pdf
You can go with custom designed part if your order quantity is much more.
The information's attached above are sufficient.But according to me it is also necessary to mention the OPERATING TEMPERATURE, ROHS...Bcz this also plays a major role.
Thanks & Regards
Dinesh M
I would provide the operating frequency and maximum applied volt-seconds, because both the operating flux density and core losses are a function of that.
