I am trying to make a transformer in ADS momentum..
i am using following equations to calculate L and Q of individual inductors
L = imag(1/y(1,1))/(2*pi*f)
Q = imag(y(1,1))/real(y(1,1))
replace y(1,1) by y(2,2) for second inductor
Qustion1) does this formula hold true when both inductors are modeled as differential inductors??
(2) how do i calculate coupling co-efficient k of the transformer??
My question was that.. How could you extract this relation between s-parameters and coupling coefficient ??
To my knowledge, coupling coefficient is a mechanical parameter and can not be pre-determined before.
How could you get this correlation ?? Which theory supports this relation behind ??
Thanks for your answers in advance..
@bigboss/Zander_ua: can any of you tell me how to assign a ground to a transformer in ADS momentum?? if i assign port 1 to one end of primary and ground the other end, ie not make a differential circuit, the analysis of equivalent circuit becomes very easy..i'll assign port 2 to one end of secondary and ground the other end of secondary too..thanks in advance..
