what parameters should i use to design my trans conductance amplifier in 180 nm process?
As a designer, you should know what are the parameters needed to design an amplifier. It normally starts with your specifications (gain,bandwidth etc.) . From that you will be able to configure out what you should do.
sir, suppose i want to have some gain. then from that how can i proceed to get the biasing current and ac voltage and most importantly the w/l ratios of the transistors?
i created a 2 stage op amp with around 90-100 db gain and phase more than 60.....now, i want to make a transconductor....dis 2 stage op-amp can be used for dat purpose or ihave to do something else.....plz guide......
