It can be used to connect a signal with one name to a signal with another name without regard to direction. In most cases, the tran construct can be replaced with the alias construct in SystemVerilog. In either case, all the drivers on all the connected signals behave as if all the drivers had been connected to the same signal.
The drivers will be resolved the same way multiple drivers are resolved when connected to the same signal. The point of the tran and alias constructs is you now have one signal with multiple names.
