gauravkothari23
Advanced Member level 2
Hi all,
i am designing a LED Driver controller using 8051 microcontroller.
i have attached a circuit diagram. i have used N76E003 Controller, and driving a BT131 Traic using controller port pin.
My problem is after a specific NO's of switching (approx 10 to 15 cycles), the triac BT131 stops working, it stays completely ON or stays completely OFF, after replacing with the new one, the things again starts working properly. have also noticed that triac does not get hot,
The load to the triac is only 12 Watts LED Driver. can anybody please let me know, why the triac stops working or gets fused. as it has a very nominal load.
The switching of triac is done using a tactile switch which is not shown in circuit diagram.
am using a non isolated power supply, to power the system.
sometimes have even noticed that it also damages the controller Port PIN
