yefj
Advanced Member level 5
Hello, i have an EFR32FG14 board which physicly looks like in the photo bellow.
I ran The following Code where they say that PC10 is my output
In the following manual shown in the link bellow there are two places on the board where PC10 could be found as shown in the photos bollow.
Which one of them has my output signal?
Thanks.
https://www.silabs.com/documents/public/user-guides/ug318-brd4257b-user-guide.pdf
Thanks.
#include "em_device.h"
#include "em_cmu.h"
#include "em_emu.h"
#include "em_chip.h"
#include "em_gpio.h"
#include "em_timer.h"
// Desired frequency in Hz
// Min: 145 Hz, Max: 9.5 MHz with default settings
#define OUT_FREQ 1000
// Default prescale value
#define TIMER0_PRESCALE timerPrescale1
* @brief
* GPIO initialization
void initGpio(void)
// Enable GPIO clock
CMU_ClockEnable(cmuClock_GPIO, true);
// Configure PC10 as output
GPIO_PinModeSet(gpioPortC, 10, gpioModePushPull, 0);
* @brief
* TIMER initialization
void initTimer(void)
// Enable clock for TIMER0 module
CMU_ClockEnable(cmuClock_TIMER0, true);
// Configure TIMER0 Compare/Capture for output compare
TIMER_InitCC_TypeDef timerCCInit = TIMER_INITCC_DEFAULT;
timerCCInit.mode = timerCCModeCompare;
timerCCInit.cmoa = timerOutputActionToggle;
TIMER_InitCC(TIMER0, 0, &timerCCInit);
// Set route to Location 15 and enable
// TIM0_CC0 #15 is PC10
TIMER0->ROUTELOC0 |= TIMER_ROUTELOC0_CC0LOC_LOC15;
TIMER0->ROUTEPEN |= TIMER_ROUTEPEN_CC0PEN;
// Set Top value
// Note each overflow event constitutes 1/2 the signal period
uint32_t topValue = CMU_ClockFreqGet(cmuClock_HFPER) / (2*OUT_FREQ * (1 << TIMER0_PRESCALE))-1;
TIMER_TopSet(TIMER0, topValue);
// Initialize and start timer with defined prescale
TIMER_Init_TypeDef timerInit = TIMER_INIT_DEFAULT;
timerInit.prescale = TIMER0_PRESCALE;
TIMER_Init(TIMER0, &timerInit);
* @brief
* Main function
int main(void)
// Chip errata
CHIP_Init();
// Init DCDC regulator with kit specific parameters
EMU_DCDCInit_TypeDef dcdcInit = EMU_DCDCINIT_DEFAULT;
EMU_DCDCInit(&dcdcInit);
// Initialization
initGpio();
initTimer();
while (1) {
EMU_EnterEM1(); // Enter EM1 (won't exit)
