Sphade
Newbie
I am trying to create a circuit that can take the input from a Li-Po battery and output a stable 5V with a maximum current draw of the load of 4A.
After checking the datasheet and using the design tool provided by the TI website, I managed to get this circuit:
And here is the layout just in case someone finds something wrong with it (left side is from something else):
After populating the components (only for the Boost converter, nothing else on the circuit) I noticed I can only draw about 1.2A before the voltage drops to around 4.3V when I hit the 1.3A threshold. Until that threshold is slowly dropping to about 4.98V at 1.2A.
I cannot understand, for any reason, why this is the case. I have to be honest here and mention that I have not actually checked the circuit myself and entirely relied on the TI design tool (a mistake on my side).
Inductors I have used with the exact same result:
I have also not populated the LDO in the schematic and tried to draw current from the VDD5V pin.
At this point I have exhausted all ideas that came to my mind.
Thank you in advance for any help!
- LMLP07A7MR68DTAS
- MWSA0603S-R68MT
