rocky79
Member level 5
Hello,
I have built a High side switch that interfaces with a low voltage relay system
for home use( existing product) and I am looking for feedback to make the switch safer and more reliable.
The touch switch that I have built connects to the low voltage relay panel via 3 wires.( Please see attachments)
Switch_High is usually 28~29 VDC.
The low voltage relay system is designed so that if you touch Switch_High wire
with the Switch_Low wire the relay built in to the low voltage system will
toggle on or off.
Going back to touch switch I made, once the switch is activated by touching it, it will
momentary forms a connection between the Switch_high and Switch_low as shown on
the schematics. The Switch will be powered by a separate 12v wall transformer.
Any feedback is appreciated.
Top Layer Layout
Bottom Layer
- Switch_High
- Switch_Low
- Ground
toggle on or off.
Top Layer Layout
Bottom Layer
