I believe it only gives a [linear] control signal. It, by itself, is not a potentiometer.
its just a resistor voltage divider but with one resistor replaced with the LDR
input audio signal >--------------resistor---------------tap------------------LDR-------------ground.
tap point is where you get the variable audio output
