calculus_cuthbert
Member level 4
Is total harmonic distortion calculation done only on sinusoidal signals or can it be done on triangular waveforms also?
JoannesPaulus said:It has to be a sine wave since it is defined as "the ratio of the sum of the powers of all harmonic components to the power of the fundamental frequency".
betwixt said:Also, distortion is a measure of deviation from a perfect waveform. If the perfect waveform is a triangle wave, an exact replica of it will have zero distortion. It should still be possible to quantify differences in terms of harmonics but the math could be horrendous (I'm not volunteering!).
Brian.
Sorry, I respectfully disagree. As FvM mentioned, the THD defines how far from a pure sinewave is your signal. There are other methods, with no specific names, that are used to measure how far your signal is from, for instance, a triangular wave or a multi-tone signal. So, I believe that if you mention total harmonic distortion you are referring to a sinusoidal signal.LvW said:JoannesPaulus said:It has to be a sine wave since it is defined as "the ratio of the sum of the powers of all harmonic components to the power of the fundamental frequency".
Sorry, just the opposite is true.
The THD factor by definition for a sinewave is zero (no harmonics).
Calculation of the THD makes sense only for non-sinusiodal waves (like triangle or everything between sinus and sqarewave).
JoannesPaulus said:LvW said:..............
Sorry, JoannesPaulus, I respectfully must confess that there was a misunderstanding between us. You are, of course, completely right that THD is "referred to a sinusoidal signal". No doubt about this.
But remember the original question: Is total harmonic distortion calculation done only on sinusoidal signals or can it be done on triangular waveforms also?
For my understanding, this sounds as if Calculus_Cuthbert thought, the THD principle could be applied either on sinusoidal or (!!!) for example on triangle waveforms. And - trying to be 100% correct - my first answer was based on the assumption that a signal which is called "sinusoidal" is really a clear sinewave with a THD=0% (knowing that this, of course, is an unrealistic case) and that for all other waveforms which deviate from this "ideal sinus" the concept of THD applies. OK?
Regards
LvW
