PowerDAC
Newbie level 3
- Joined
- Feb 19, 2008
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- nr Oxford UK
- Activity points
- 1,334
1-bit dac
I have implemented the digital part of a high end audio DAC in an FPGA. It is a single bit Delta Sigma design and an FFT of the output bitstream reveals this is working well. I now have to design a top-quality 1-bit DAC to convert the digital bitstream to an analog signal. The circuit will be implemented from discrete IC's or parts, not in an IC.
I'm aiming for a dynamic range of at least 125dB.
Bit rate is 12.288Mbps (256fs).
I have reclocked the FPGA bitstream output externally from the 98.304MHz low jitter oscillator, in a reg fed with an ultra-clean VCC so the bitstream itself has low jitter.
I considered the following ideas:
1. Switched capacitor integrator. This seems to be done quite often on-chip, but will a discrete design be able to realise good enough performance? The output of the SC filter would hopefully have low enough slew to feed into a conventional CT active filter. Are there any any practical guidelines for design of such circuits? The literature I've found seems to assume you're doing it in an IC or are interested only in the math, and that all components are ideal.
2. Switchable current source into ??? Ideas? Suggestions?? I would have thought that changing a fast voltage slew into a fast current slew wouldn't be of much help, but ???
3. Precison low noise reference (eg Walt Jung's 1.25nV/rtHz circuit) switched with a small switching bridge into a passive differential-in differential-out pre-filter. Bridge switches would be driven from the bitstream converted to RZ (return zero). I would hope the RZ format would ensure each symbol's rise and fall times would be repeatable. The output from the passive filter should have slew low enough to feed into a conventional diff input active filter.
4. Something based loosely on 3 but employing resonant circuitry to created perfectly repeatable pulses of a raised cosine shape.
Does anyone have any ideas or suggestions on this circuit? Anyone have experience in the topologies used for such high end DACs who could point me in the right direction?
Thanks in advance
Thanks in advance
