vsmGuy
Advanced Member level 2
Do you know of some tool that can show the diff between two Intel Hex files?
If it is customzed for PIC/AVR in some way - even better!
Enlightenment said:Don't compare the intel hex files, but instead create another format where the output is always the same, like a final hex-ascii of the memory that you want to compare..
hexo input.hex out.hex
srizbf said:so you want to compare two hex files , one from your compiler output and one read from the programmed controller ?
for that purpose why not you straight away use 'verify ' feature of the programmer .?
