robismyname
Full Member level 6
- Joined
- Jan 17, 2008
- Messages
- 390
- Helped
- 11
- Reputation
- 22
- Reaction score
- 9
- Trophy points
- 1,298
- Location
- Central Florida
- Activity points
- 4,603
what does too much voltage drop do
I am providing 3.3 volts to the emitters of the 3906 transistors and 3.3 volts to the bases of the 3904 transmitters. As you can see I made a 3.3 volt bus in my circuit (see attached document) and the purpose of the document is to show you how i did it. The problem is that I measure 3.3 volts across the bus but when the transistors are connected to the MCU via connectors I notice my voltage drops down to .6 volts. Any idea why this is happening and how to correct it?
