[SOLVED] too few arguments to function `void function(per*, int)' problem
lignin
Junior Member level 2
hello ;
I have a problem with the following code.
#include<stdio.h>
#include<string.h>
#include<conio.h>
typedef struct person {
        char name[20];
        int age ;
}per;
void function(per *pointer, int newAge){// problem is here.
     pointer->age = newAge;
int main(){
      per per1;
      function(&per1);
      printf("age %d",per1.age);
      getch();
I received following error : 12 C:\Dev-Cpp\Untitled1.cpp too few arguments to function `void function(per*, int)'
so what is the problem ?
thanks for your answer.
you define the function with two parameters
but only call it with one
      function(&per1);
it needs two parameters, e.g.
      function(&per1, 10);
