Token ring simulation : Using opnet
deverahul2003
Newbie level 1
Hello everyone , Here today we will discuss about token ring simulation step by step.
1st: LEARNING:
Token Ring network can be summarized by the following steps:
  • Active monitor node: generates the token and supervise it, being sure that won’t be lost. If the token is lost, the monitor will generate another token.
  • Token: is continuously circulated on the ring passing through each node. When a node has a message to send, it brings the rights to send holding the token, modifying it by inserting the PDU in the specific field and then transmit.
  • The frame will be read by each node in the ring.
  • When a node identifies itself being the destination for the message it brings the data and sends back the token with the acknowledgement bit set to “1â€.
  • The source node receiving the acknowledgment removes the already sent PDU
  • from the send queue.
  • If the Timer Holding Token is not expired another frame can be sent. This timer
  • is useful to ensure fairness.
  • When the token is no more needed both for timer expiration or empty queue
  • cases, it is released and starts again to circulate, ready to be used by another
  • node.
