You need to study some anatomy!
The total dissipation is slightly more than 6W which is very small but ALL depends on the source.
Without knowing the details, let us assume that the diode dissipates 2W and the FET does the rest.
There are two heatsinks right? One for the diode and the other for the MOSFET.
What is the nature of the plastic enclosure? If it is black and thin, perhaps you can get away with it. If you have a choice, select a corrugated surface.
An adult, with a 2 m2 surface and body temp 32C, radiates about 100W when the ambient is around 20C.
I guess you will be fine.
