- to + voltage converter - suggest a circuit
anubhava
Newbie level 3
Newbie level 3
buck-bust converter
Hi
I want to convert -12v at 0.5 amp to +12v or +5v.
I am exhausted in searching. please suggest me a circuit
or something.
my id is perfectanurit@gmail.com
thanx in advance
look to buck/bust regulator topologie. It inverts voltage.
Re: - to + voltage converter
As Dmitron already pointed out, a buck-boost converter is worth considering. please see at
https://en.wikipedia.org/wiki/Buck–boost_converter
Also, you may use Google to find about the stuff. Other great sources of info are the component suppliers making switchmode converter chips. (For example www.linear.com/ , www.st.com , www.national.com and many others) Look for both data sheets and application notes - they give a good starting point.
In general, designing such a converter may seem easy due to many design examples available, but a beginner may have really big trouble with the basic PWB design rules, properties of capacitors and inductors, and regulating feedback loop stability. Read carefully the application notes, and try to understand also the passive component properties and do not change/substitute those without understanding what is critical. Otherwise you may generate more smoke than anything else...
Good luck!
-ted
