[SOLVED] to make pic 16f628 based cyclic on off timer
hamidooon
Junior Member level 1
i want to build on off programable switch using pjc when i search on net then this project is find.
link of project=
https://embedded-lab.com/blog/programmable-digital-timer-switch-using-a-pic-microcontroller/
but the problem is this code is only for one cycle of relay on and off operation ...
i need relay on off on off after given time unlimited untill reset ...
.help to modify this code.....
code is written in MICROC
Here is ckt diagram
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
272
273
274
275
276
277
278
279
280
281
282
283
284
285
286
287
288
289
290
291
292
293
294
295
296
297
298
 * Project name: Programmable Digital Timer
 * Copyright:
     (c) Rajendra Bhatt, 2010.
     MCU:             PIC16F628A
     Oscillator:      XT, 4.0 MHz
// LCD module connections
 sbit LCD_RS at RA0_bit;
 sbit LCD_EN at RA1_bit;
 sbit LCD_D4 at RB4_bit;
 sbit LCD_D5 at RB5_bit;
 sbit LCD_D6 at RB6_bit;
 sbit LCD_D7 at RB7_bit;
 sbit LCD_RS_Direction at TRISA0_bit;
 sbit LCD_EN_Direction at TRISA1_bit;
 sbit LCD_D4_Direction at TRISB4_bit;
 sbit LCD_D5_Direction at TRISB5_bit;
 sbit LCD_D6_Direction at TRISB6_bit;
 sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connections
 sbit MODE at RA2_bit;
 sbit SELECT at RA3_bit;
 sbit ENTER at RA4_bit;
 sbit START at RB0_bit;
 sbit RelaySW at RB3_bit;
// Define Messages
 char MSG1[] = "Device is ";
 char MSG2[] = "OFF";
 char MSG3[] = "ON ";
 char MSG4[] = "HH:MM";
 unsigned short HHMM_Pos[] = {6, 7, 8, 9, 10};
 unsigned short ON_Time[] = {0, 0, 10, 0, 0}; // 10 + 48 is :
 unsigned short OFF_Time[] = {0, 0, 10, 0, 0};
 unsigned short Mode_Select = 0 ; // 0:ON, 1:OFF
 unsigned short i, j, k, Timer_On, Get_Input, Cur_Pos, Cur_On;
 unsigned short temp, refresh, Num, HalfSec, Blink, ChangeMin=0;
 unsigned short OFF_HH, OFF_MM, ON_HH, ON_MM;
 void Disp_First_Row(){
  Lcd_Out(1,1, MSG1);
  if (RelaySW == 0) Lcd_Out(1,11, MSG2);
  if (RelaySW == 1) Lcd_Out(1,11, MSG3);
 void Disp_Char(unsigned short col, unsigned short chr){
  Lcd_Chr(2, col, chr+48);
 void Disp_Time(){
   for(i=0; i<5; i++){
      if(!Mode_Select){
       Lcd_Out(2,1, MSG2);
       Disp_Char(HHMM_Pos[i],OFF_Time[i]);
      if(Mode_Select){
       Lcd_Out(2,1, MSG3);
       Disp_Char(HHMM_Pos[i],ON_Time[i]);
 void play_sound(){
  Sound_Play(2500, 500);
 void debounce(){
  Delay_ms(250);
 void cursor_left(){
   for(j=0; j<5; j++){
      Lcd_Cmd(_LCD_MOVE_CURSOR_LEFT);
 void disable_timer(){
  INTCON = 0x00;
  RelaySW = 0;
  INTCON.T0IF = 0;
  Timer_On = 0;
  Blink = 0xff;
  Mode_Select = 0;
  Disp_First_Row();
  Disp_Time();
  play_sound();
 void interrupt() {
  Num ++;           // Interrupt causes Num to be incremented by 1
  if(Num == 9) {
   HalfSec ++;      // Increase sec
   Num = 0;
   Blink = ~Blink;
   if (HalfSec == 120){
    HalfSec = 0;
    ChangeMin = 1;
  TMR0 = 39;        // TMR0 returns to its initial value
  INTCON.T0IF = 0;  // Bit T0IF is cleared so that the interrupt could reoccur
void main() {
  CMCON = 7;           // Disable Comparators
  TRISA = 0b00111100;
  TRISB = 0b00000001;
  Sound_Init(&PORTB,2); // Initialize Buzzer o/p pin
  RelaySW = 0;
  Timer_On = 0;
  Get_Input = 0;
  Cur_Pos = 0;
  Cur_On = 0;
  refresh = 0;
  Num = 0;
  HalfSec = 0;
  Lcd_Init();                // Initialize LCD
  Lcd_Cmd(_LCD_CLEAR);       // Clear display
  Lcd_Cmd(_LCD_CURSOR_OFF);  // Cursor off
  Lcd_Out(1,1, "Copyright @");
  Lcd_Out(2,1, "Embedded-Lab.com");
  i=0;
  while(i<4){
   debounce();
   i ++;
  Disp_First_Row();
  Lcd_Out(2,4,"-");
  Lcd_Out(2,12, MSG4);
  Disp_Time();
  do {
   if(!MODE && !Timer_On){
    debounce();
    if(!Get_Input){
     Mode_Select = ~Mode_Select;
     Disp_Time();
    if(Get_Input){
     if(!Mode_Select){
      OFF_time[Cur_Pos] = OFF_time[Cur_Pos]+1;
      temp = OFF_time[Cur_Pos];
      switch (Cur_Pos){
       case 0: if(temp > 9) OFF_time[Cur_Pos]=0;
               break;
       case 1: if(temp > 9) OFF_time[Cur_Pos]=0;
               break;
       case 3: if(temp > 5) OFF_time[Cur_Pos]=0;
               break;
       case 4: if(temp > 9) OFF_time[Cur_Pos]=0;
               break;
      Disp_Char(6+Cur_Pos, OFF_time[Cur_Pos]);
     if(Mode_Select){
      ON_time[Cur_Pos] ++;
      temp = ON_time[Cur_Pos];
      switch(Cur_Pos){
       case 0: if(temp > 9) ON_time[Cur_Pos]=0;
               break;
       case 1: if(temp > 9) ON_time[Cur_Pos]=0;
               break;
       case 3: if(temp > 5) ON_time[Cur_Pos]=0;
               break;
       case 4: if(temp > 9) ON_time[Cur_Pos]=0;
               break;
      Disp_Char(6+Cur_Pos, ON_time[Cur_Pos]);
   }   // END if(!MODE)
   if(!SELECT && !Timer_On){
     debounce();
     Get_Input = 1;
     if(Cur_On) {
       Cur_Pos ++;
       if (Cur_Pos == 2) {
         Lcd_Cmd(_LCD_MOVE_CURSOR_RIGHT);
         Cur_Pos ++;
       if(Cur_Pos > 4) {
         Cur_Pos = 0;
         cursor_left();
       else Lcd_Cmd(_LCD_MOVE_CURSOR_RIGHT);
     if(!Cur_On) {
       Cur_On = 1;
       cursor_left();
       Lcd_Cmd(_LCD_UNDERLINE_ON);
   if(!ENTER && Get_Input){
    debounce();
    Get_Input = 0;
    Cur_On = 0;
    Cur_Pos = 0;
    Disp_Time();
   if (!START && !Get_Input){
    debounce();
    switch(Timer_On){
    case 0: play_sound();
            Timer_On = 1;
            OPTION_REG = 0x07; // Prescaler (1:256) is assigned to the timer TMR0
            TMR0 = 39;          // Timer T0 counts from 39 to 255
            INTCON = 0xA0;     // Enable interrupt TMR0 and Global Interrupts
            INTCON.T0IF = 0;
            Mode_Select = 0;
            Blink = 0;
            Disp_Time();
            break;
    case 1: disable_timer();
            break;
   if(Timer_On){
    OFF_HH = OFF_Time[0]*10 + OFF_Time[1];
    OFF_MM = OFF_Time[3]*10 + OFF_Time[4];
    ON_HH = ON_Time[0]*10 + ON_Time[1];
    ON_MM = ON_Time[3]*10 + ON_Time[4];
    switch(Blink){
     case 0: Lcd_Chr(2,8,' ');
             break;
     case 255: Lcd_Chr(2,8,':');
             break;
    if(!OFF_HH && !OFF_MM &&!RelaySW){
     if(ON_HH || ON_MM){
      RelaySW = 1;
      Mode_Select = 0xff;
      Disp_First_Row();
      Disp_Time();
      play_sound();
     else {
      disable_timer();
    if(!ON_HH && !ON_MM && RelaySW){
     disable_timer();
     play_sound();
    if(ChangeMin) {
     switch(Mode_Select){
      case 0: if(OFF_MM == 0 && OFF_HH>0){
               OFF_MM = 59;
               OFF_HH -- ;
              else if (OFF_MM >>0) OFF_MM --;
              OFF_Time[0] = OFF_HH/10;
              OFF_Time[1] = OFF_HH%10;
              OFF_Time[3] = OFF_MM/10;
              OFF_Time[4] = OFF_MM%10;
              break;
      case 255: if(ON_MM == 0 && ON_HH>0){
               ON_MM = 59;
               ON_HH -- ;
              else if(ON_MM >> 0) ON_MM --;
              ON_Time[0] = ON_HH/10;
              ON_Time[1] = ON_HH%10;
              ON_Time[3] = ON_MM/10;
              ON_Time[4] = ON_MM%10;
              break;
     ChangeMin = 0;
     Disp_Time();
  }while(1);
The first thing you should do when analyzing the code, scribble a sketch of its operation, preferably a graphics mode with the block diagram. This way will understand where you need to make the necessary modifications, which in my opinion are quite simple.
DEar andre_teprom sir ,
I analyzed the code and comes to one point that when given values are decreased and off on relay cycle is stopped then how can we recall that values i focus on following code only see
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
if(Timer_On){
    ON_MM = ON_Time[3]*10 + ON_Time[4];//these valuse are decresing
    switch(Blink){
             break;
             break;
    if(!OFF_HH && !OFF_MM &&!RelaySW){// if off time and relay is off         then on time is started decreasing
     if(ON_HH || ON_MM){
      RelaySW = 1;
      Mode_Select = 0xff;
      Disp_First_Row();
      Disp_Time();
      play_sound();
     else {
      disable_timer();
    if(!ON_HH && !ON_MM && RelaySW){//when on time is 0 but relay is1 then timer desabled
     disable_timer();// i removed this then timer is still on... and relay is at off position
     play_sound();
    if(ChangeMin) { // this is main desresing program which decrese main values
               OFF_MM = 59;
               OFF_HH -- ;
              break;
               ON_MM = 59;
               ON_HH -- ;
              break;
     ChangeMin = 0;
     Disp_Time();
  }while(1);
Img_DigitalTimerTimeSetup.jpgImg_DigitalTimerFinished.jpgImg_DigitalTimerCktSetup1.jpg
