imisendo_4036
Newbie level 2
hello frenz...
i actually do dc motor speed controller right now...to maintain speed even load change....project from internet
but the problem is when i run the project in simulator..
the result is not as expected...all LED are on...can't maintain the speed
can anyone suggest what should i do....plzzz
[/img]
[/img]
;PROGRAM TO CONTROL DC MOTOR SPEED
;*****DECLARATION*****
PROCESSOR 16F873
#include "p16F873.INC"
__CONFIG _HS_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF
errorlevel -302
;*****DECLARE****
speed equ d'256'
change equ d'1'
led equ h'20'
;****PROGRAM START*****
org 0
goto main
org 4
goto int
;*****INITIALIZATION PROCESS******
main
;*****PORT****
bsf 03h,5
movlw b'00000001'
movwf 85h ;set port A bit 0 as input(AN0)
clrf 86h ;port b as output
clrf 87h ;port c as output
bcf 03h,5
;****A/D CONVERTER*****
movlw b'10000001'
movwf 1Fh ;adcon0
bsf 03h,5
movlw b'00001110'
movwf 9Fh ;adcon1
bcf 03h,5
;*****PWM*****
clrf 11h ;tmr2
movlw d'127'
movwf 15h ;ccpr1L
bsf 03h,5
movlw d'255'
movwf 92h ;pr2
bcf 03h,5
movlw b'00000110'
movwf 12h ;t2con
movlw b'00001100'
movwf 17h ;ccp1con
;*****COMPARE MODE*****
clrf 0Fh ;tmr1h
clrf 0Eh ;tmr1L
movlw h'61'
movwf 1Ch;ccpr2h
movlw h'A8'
movwf 1Bh;ccpr2L
movlw b'00000001'
movwf 10h;t1con
movlw b'00001011'
movwf 1Dh;ccp2con
;****INTERRUPTION CONTROL******
bsf 03h,5
movlw b'00000001';ccp2ie enable
movwf 8Dh;pie2
bcf 03h,5
movlw b'11000000';gie on & peie on
movwf 0Bh;intcon
wait
goto $
;*****INTERRUPTION PROCESS*****
int
clrf 0Dh;pir2
check
btfsc 1Fh,2;cek A/D siap x?
goto check
movlw 1Eh;adresh, A/D result high register
sublw speed
btfsc 03h,0;bit test,skip next instruction if clear
goto check1
;****LOW SPEED*****
movlw 15h;ccpr1L
addlw change
btfss 03h,0
movwf 15h;ccpr1L
goto led_cont
check1
btfsc 03h,2
goto led_cont
;****FAST SPEED******
movlw change
subwf 15h,1;ccpr1L-1
btfsc 03h,0
goto led_cont
clrf 15h
;******LED CONTROL******
led_cont
comf 15h,0
movwf led
movlw b'00010000
subwf led,0
btfsc 03h,0
goto led1
movlw b'00000000'
movwf 06h
goto int_end
led1
movlw b'00100000'
subwf led,0
btfsc 03h,0
goto led2
movlw b'00000001'
movwf 06h
goto int_end
led2
movlw b'01000000'
subwf led,0
btfsc 03h,0
goto led3
movlw b'00000011'
movwf 06h
goto int_end
led3
movlw b'01100000'
subwf led,0
btfsc 03h,0
goto led4
movlw b'00000111'
movwf 06h
goto int_end
led4
movlw b'10000000'
subwf led,0
btfsc 03h,0
goto led5
movlw b'00001111'
movwf 06h
goto int_end
led5
movlw b'10100000'
subwf led,0
btfsc 03h,0
goto led6
movlw b'00011111'
movwf 06h
goto int_end
led6
movlw b'11000000'
subwf led,0
btfsc 03h,0
goto led7
movlw b'00111111'
movwf 06h
goto int_end
led7
movlw b'11100000'
subwf led,0
btfsc 03h,0
goto led8
movlw b'01111111'
movwf 06h
goto int_end
led8
movlw b'11111111'
movwf 06h
;******END INTERRUPTION******
int_end
retfie
;**********END OF DC MOTOTR SPEED CONTROLLER*******
END
end
