to generate a digital signal
pushpa
Newbie level 3
Newbie level 3
I have two clks, Clk1 and Clk2. I want to generate an output signal X= 1 when Clk1 is ahead of Clk2 and X=0 when Clk1 is behind Clk2.
Hi pushpa,
Suppose the period of the 2 clk is same.
You can generate 2 edge detect signals(just xor the non-pipe version with piped version), clk1_edge, clk2_edge. Then,
always@(clk1_edge, clk2_edge)
if(clk1_edge && !clk2_edge)
X = 1;
else
x = 0;
    pushpa
how to test which is ahead,
what is your mean?
i am not sure i understand your question correcttly.
if clk1 is ahead of clk2, but for the next period of clk1, it maybe behind clk2
the frenquency of the two clock is the same?
maybe you can try as follow
always(@ posedge clk1)
if(clk2)
x<=1'b0;
else
x<=1'b1;
but before you decide to do as above, maybe you must use two flip-flop to synchronize clk2 with clk1
Its very simple you just need to sample one clock by the othere!
Here it is!!
`timescale 1ns/1ps
module phase_comp(
   // Outputs
   x_out,
   // Inputs
   clk1, clk2
   input clk1, clk2;
   output      x_out;
   reg         clk2_r, clk2_rr;
   assign      x_out = clk2_rr;
   always @(posedge clk1) begin
      clk2_r <= clk2;
      clk2_rr <= clk2_r;
   end
endmodule // phase_comp
module test();
   reg                  clk1;
   reg                  clk2;
   wire                 x_out;
   phase_comp phase_comp(
                         // Outputs
                         .x_out         (x_out),
                         // Inputs
                         .clk1          (clk1),
                         .clk2          (clk2));
   reg         clk;
   reg [1:0]   count;
   reg         sel;
   always @(count or sel) begin
      clk1 <= sel ? count[0] : count[1];
      clk2 <= sel ? count[1] : count[0];
   end
   initial begin
      $shm_open("WAVEFORM");
      $shm_probe(test, "AS");
      count = 0;
      sel = 0;
      clk = 0;
      #400;
      sel = 1;
      #400;
      $finish;
   end // initial begin
   always @(posedge clk) begin
     count[0] <= count[1];
     count[1] <= ~count[0];
   end
   always #5 clk = ~clk;
endmodule // test
Here I am assuming that the clks are asynchronous hence the double flop
synchronizer.
hi, nand_gates
Your assumption is that the two clock are the same in frequence and different in phase.
You use one clock to sample the other clock level.
Then it is to decise which clock is leading by the sampled level(0/1).
When the phase between two clocks is very small.
the result may wrong. In this situation, it is no matter to find which one is leading extractly.
But I still have a question that will the level of sample signal be high or low always?
Or it is changed in each one/two/three cycles(it is not stable)?
Sincerely,
Jarod
yes i think so
for clk1, clk2 is a asynchronism signal
The frequency of the two clk must be comparable ,if not ,the question is meanless.
