Vibrant2020
Newbie level 6
Purpose : to drive ultrasonic transducer at 40kHz
Parts used:
1. Ultrasonic Transducer (taken out from general module from HC-SRO4)
2. PWM generator module with led display (micro usb 2 channel pwm generator with led)
3. LM386 amplifier module
4. +5v/500mA for PWM module
5. +9V/7AH (battery) for LM386 amplifier module
For testing purpose, The following parts used:
1. LED
2. Buzzer (working on 6 to 9 V range)
PWM Generator Module Testing Status:
Have connected the LED at the output and tested. It works fine.
LM386 amplifier module testing status +9V:
Have connected the Buzzer and tested. Works okay but there is not enough amplification. Voltage at output pin was around 3V. When i rotate the 10K pot to low, it correctly off the buzzer sound. But when i increase, not enough sound i obtained.
Now I connected the PWM generator module's PWM1 output to LM386 amplifier Module and connected the Ultrasonic transducer at the LM386 output pin. I set the PWM1 output as 40khz / 50% duty cycle (40.0 on led display) and switched on. I put my phone mic in front of the transducer and tested. I didn't get any audio signal on my phone's mic.
PWM module used:
LM386 Amplifier Module used::
Your opinion & suggestion welcome.
Thank you,
Vibrant
Pictures attached For your referrence.
Parts used:
1. LED
PWM module used:
Thank you,
Vibrant
--- Updated ---
