To declare a user defined primitive in Verilog
jayanth03
verilog primitive
Hi All,
Below is the example code I am trying to Synthesize in Xilinx ISE 8.1:
///////////////Example code to declare a UDP and use it in a module////////////////////////
`timescale 1ns / 1ps
module top(DataA, DataB, Control, mux);
    input DataA;
    input DataB;
    input Control;
    output mux;
  multiplexer
  MUX1 (mux, Control, DataA, DataB) ;
endmodule
primitive multiplexer (mux, control, dataA, dataB) ;
output mux;
input control, dataA, dataB;
table
// control   dataA  dataB  mux
 0 1 ? : 1 ; // ? = 0 1 x
 0 0 ? : 0 ;
 1 ? 1 : 1 ;
 1 ? 0 : 0 ;
 x 0 0 : 0 ;
 x 1 1 : 1;
endtable
endprimitive
If you synthesize this code in Xilinx ISE 8.1 you will be able to reproduce the following error:
ERROR:Xst:850 - "top.v" line 28: Unsupported Switch or UPD primitive.
Please let me know if its ok to declare a UDP outside a module in any Verilog_Module.v source or there is there something wrong with this declaration...
I tried declaring the UDP with in the module and that did not work either...
Appreciate for your time and help.
Regards
Jayanth
primitive verilog
Hi
I want to ask
do you have passed compilation on any other tool.
thanks
verilog primitives
No, as of now the only tool I have access to is Xilinx ISE 8.1. What other tools are you looking at??? I think it should work even on Xilinx ISE cuz I have pulled up the example code from Xilinx web resources...
This information can be found here: **broken link removed**.
Thanks
Jayanth
According to the XST guide, UDP is not supported for synthesis.
That means it can be used in simulation only.
See **broken link removed**
    jayanth03
