tny268 (SMPS) layout thermal considerations
alexxx
Greece
Hi!
I am about to design a single layer board that uses tny268. I would like the layout design to be made exactly as the datasheet describes.
http://www.datasheetcatalog.org/datasheet/powerint/TNY268P.pdf
What I failed to understand from the datasheet is if this copper is for top layer or bottom layer or doesn't mind and can be used for both layers as well. It says "TOP VIEW", but I suppose that this stands for material view. This is important for me because it is going to be a single layer board and tny268 will be in through hole case.
Also the datasheet uses the term "Copper underneath the TinySwitch-II", avoiding to mention which layer would that be.
According to table 1 in page 1, both through hole and smd cases have the same output power, but I need to be sure about copper layer.
Thanks in advance.
