doctorworm
Newbie level 6
Hi Everyone,
I'm designing a MMIC PA at ~40 GHz and have noticed that the EM simulation results for my matching networks show VERY different results when switching between TML and TML-zero ports.
I've always been told that TML ports are the best option if they're on the boundary of the structure (i.e. no other structure in the layout extends past them), otherwise TML-zero should be used. I've also found that a stand-alone element like a MIM cap, directional coupler, transformer or a length of line etc. closely resembles the schematic equivalent if TML ports are used... in my mind, "TML = good, TML-zero = not-so-good".
TML-zero ports appear to make 50 Ohm lines look capacitive on the Smith chart, and MIM cap exhibit a much lower self-resonances, so I generally don't trust them.
So... after designing a matching network using TML ports at the input (drain manifolds) and output (gate manifolds), I had to change the output ports to TML-zero, as other structures extended beyond the TML ports and this totally messed up the response. We're talking total mismatch and about half the bandwidth lost. No amount of +/- MLIN length or lumped L/C value can bring me back to me TML-port response so I don't know what the change in port calibration is doing to my circuit and, more importantly, whether using TML ports at the transistor gate/drain manifolds was the correct thing to do in the first place.
Any advice???
Any advice???
