prcken
Advanced Member level 1
Hi all
Please help to check the attached schematic of Transmission line pulse generator and its corresponding waveforms at each node.
S1 is a switch controlled by the voltage pulse “swctl” as shown in the picture, when swctl is 0V, S1 is open (huge resistance), when swctl is 1V, S1 is closed (zero resistance).
I have 2 questions:
Q1: why the coaxial cable cannot be recharged to generate a series of pulses? It should be recharged!
Q2: why the voltage at far end of the coaxial cable drops abruptly from 100V to 0? I cannot see a negative reflected waveform.
Thanks
Kehan
I have 2 questions:
Thanks
Kehan
