boylesg
- Joined
- Jul 15, 2012
- Messages
- 1,023
- Helped
- 5
- Reputation
- 10
- Reaction score
- 6
- Trophy points
- 1,318
- Location
- Epping, Victoria, Australia
- Activity points
- 11,697
Fairly easy if the LED supply voltage is 5V - same as the TLC5490 supply. Just use a PNP transistor.
But it doesn't work if 12V is on the emitter of the PNP transistor - the PNP will always be turned on since the 12V on the emitter is always greater than the max 5V that can be applied to the base through the TLC5490 channel?
