TL494 EXTERNAL COMPONENTS CALCULATIONS
JOHNSON FIANU
Newbie level 3
Newbie level 3
tl494
how can i calculate the external components of TL494 in switch mode (step up and step down) power suppply. attached is example of a step down
VO= 5V
V1 =32V
IO =10A
f = 20 KHz
tl494 step up
Maybe you can post some of the calculations you already did, and point out the things you don't understand.
tl494 example
the TL494 data sheet did provide equations for the calculations of the external resistors thus R1 to R12. i have already calculate the other component. i will be greatful if you can help me. thanks
tl494 step down
just post your schematic, the datasheet I looked into from TI did not have R1 to R12 on...
tl494 schematic
Design Example
The following design example uses the TL494 to create a 5-V/10-A power supply. This design is
based on the following parameters:
VO = 5 V
VI = 32 V
IO = 10 A
fOSC = 20-kHz switching frequency
VR = 20-mV peak-to-peak (VRIPPLE)
ΔIL = 1.5-A inductor current change
Attached is an example of the schematic. thanks
design example tl494
Ok, and what do you need to calculate?
