eem2am
Banned
Hello,
I do isolated , offline flyback.
TL431/Opto-coupler feedback.
The problem is, the 1K resistor that's across the opto-diode to provide the TL431 bias current, places a voltage across the opto-diode of 1 Volt....
...this in turn makes it conduct current, which is a big big problem on maximum load, because if 180uA is drawn through the opto-diode then this has the effect of stopping the primary-side PWM control IC from switching.
The control current to stop the PWM controller is just 90uA (actually, 90uA is the lower tolerance level, but it could obviously still occur)
......so
how do you get round the problem of the TL431 drawing some of its bias current through the opto-diode, unwantedly.?
......so
