TL431 in SMPS feedback replaced with LT1009?
eem2am
Banned
Why are you sure it can not be used? Did you try it or is it just an assumption?
Maybe the difference is mainly the small signal frequency response of the regulator (just based on the two pulse response charts in the data sheets), and you need to adapt the control loop compensation.
Stefaan
Reactions: treez
    T
So I assume you didn't try it yet. If you have a working system with the TL431, it should be not too difficult to test a LT1009.
If you assume there is virtual no current in the "ref" input, and the cathode-current versus cathode voltage (in the case the cathode is connected directly to the reference) behaves the same, you should be able to swap them.
On a larger scale , it doesn't matter how the component is made internally, if the behavior on the pins is more-or-less the same.
I've put the characteristics next to each other in following pdf. Be careful, the scale of the LT1009 is logarithmic.
  • comp.pdf
I think, it's pretty obvious, that LT1009 can't be used in a similar circuit as TL431, because the low impedance internal voltage divider and other internal circuit details don't allow the "cathode" terminal to act independant of the reference voltage. You need a shunt regulator with high impedance output terminal and suffcient output voltage range.
Reactions: treez
    T
FvM,
Indeed, I overlooked the input impedance, you can not do the voltage divider at the input to set the desired output voltage of your power supply if using the LT1009.
Stefaan
