TL431 driving a P mosfet help
andrew257
Member level 2
Member level 2
Solved. TL431 requires 1mA current to stabalise.
could you please give some more information.
as the circuit is a simulator type , please tell what is V1 and loads 1 and 2
in the real circuit.
when the mosfet is supposed to open .(...just before 9v ...
means at 8.9 , 8.8 ..etc?)
are you supplying the backup power from supercap ?
srizbf
23rdmay2010
Added after 4 hours 52 minutes:
including a diode after the drain to load may help.
please check whether it is.
srizbf
23rdmay2010
