flote21
Advanced Member level 1
Hello people. I am very frustrated right now. I designed a PCB to convert the anaolg signal provided by a image sensor into digital impulses.
In my first revision of the board I made several mistakes in Altium (I place the footprints mirrored) but in the end, I was able to run the board without too much problems and it is working properly. But now I made a new revision of my PCB and little swing in the image is displayed when the sensor is running. it is like a electric noise generated in the pcb but I cant figure out where it is the origin...because the new rev the same layout and the same components that the previous revision. The only change that I did was place the components in the right way (no mirrored). Any tip to figure out the origin of noise problems?
Thanks
Thanks
