From what I know, critical path is the longest path between two flip-flops in a design.
However, based on the timing report, the critical is not between two flip-flops.
Can someone please explain to me why is that?
Does ACIS and FPGAs have different critical path definition?
Report : timing
-path full
-delay max
-max_paths 1
-sort_by group
Design : ProcessingElement
Version: J-2014.09-SP2
Date : Mon Feb 26 08:42:27 2018
Operating Conditions: cb13fs120_tsmc_max Library: cb13fs120_tsmc_max
Wire Load Model Mode: enclosed
Startpoint: QC[2] (input port clocked by Clk)
Endpoint: LeftOut[0] (output port clocked by Clk)
Path Group: Clk
Path Type: max
Des/Clust/Port Wire Load Model Library
ProcessingElement 8000 cb13fs120_tsmc_max
Point Incr Path
clock Clk (rise edge) 0.00 0.00
clock network delay (ideal) 0.30 0.30
input external delay 2.00 2.30 r
QC[2] (in) 0.00 2.30 r
U1/Z (bufbd1) 0.09 2.39 r
LUT/U5/ZN (inv0d1) 0.74 3.13 f
Algorithm/Iyij/Mij1/add_0_root_add_0_root_add_17_2/U1_1/CO (ad01d0)
0.50 3.63 f
Algorithm/Iyij/Mij1/add_0_root_add_0_root_add_17_2/U1_2/CO (ad01d0)
0.28 3.91 f
Algorithm/Iyij/Mij1/add_0_root_add_0_root_add_17_2/U1_3/CO (ad01d0)
0.28 4.18 f
Algorithm/Iyij/Mij1/add_0_root_add_0_root_add_17_2/U1_4/CO (ad01d0)
0.28 4.46 f
Algorithm/Iyij/Mij1/add_0_root_add_0_root_add_17_2/U1_5/CO (ad01d0)
0.28 4.73 f
Algorithm/Iyij/Mij1/add_0_root_add_0_root_add_17_2/U1_6/S (ad01d0)
0.34 5.07 r
Algorithm/Iyij/Mij1/U4/Z (an02d1) 0.16 5.23 r
Algorithm/Iyij/LeftComp/U38/ZN (oai221d1) 0.36 5.59 f
Algorithm/Iyij/LeftComp/U40/Z (aoim22d1) 0.29 5.88 r
Algorithm/Iyij/LeftComp/U29/Z (aor21d1) 0.28 6.16 r
Algorithm/Iyij/LeftComp/U3/ZN (inv0d1) 0.28 6.44 f
Algorithm/Iyij/LeftComp/U13/Z (aor22d1) 0.63 7.08 f
LeftOut[0] (out) 0.00 7.08 f
data arrival time 7.08
clock Clk (rise edge) 40.00 40.00
clock network delay (ideal) 0.30 40.30
output external delay -1.65 38.65
data required time 38.65
data arrival time -7.08
slack (MET) 31.57
