hcu
Hello all,
I am doing synthesis and implementation on a vcu108 FPGA board with a vivado tool.
case 1: my constraint for the clock is 10 ns. here i get slack as 0.7 positive slack and a 0.025 positive hold slack. And a dialogue "timing constraints are met" is shown. From this i can say the maximum operating freq of this design is around 107 mhz.
case 2 : when i change the clock constraint to 4.0 ns. here i got a slack of -1.580 negative and a 0.032 positive hold slack. And a dialogue "timing constraints are not met" is shown. one can see a calculated fmax on paper is 180 mhz.
why both analysis not concluding to the same fmax. number ?? Is it because of consideration of different paths at different runs. ??
