slinky
Newbie level 1
![Newbie level 1](/styles/images/ranks/alevel1.gif)
pic16c55 assembler
First of all, hello to all and HAPPY NEW YEAR!
Now, i've designed a circuit including the above microcontroller and i've "run" the assembly code in a simulator called MPLAB IDE.Unfortunately, i've never managed to see it working properly.Note tha it contains no errors and it must be correct.Running it in the simulator i can't see the counting from 0-15 secs, since the algorithm demands the button START to be pushed in order to start the timer.I can't do such a thing during the simulation!Someone could say:"OK then.Just programme it once and if it doesn't work then make some changes.".Well such a thing can't be done, since the PIC16C55 is an one-time-programmable chip!Once the assembly code is wrong, the chip becomes useless!What should i do?Any website that might help?
And the worst of all is that i must have completed this project by Thursday!It's an S-O-S situation!Thank u all in advance.
Any advice is welcome!
PS:Anyone who wants to check my assembly code just say it!
