balajibaski
Newbie
I'm a beginner learning ESP32 using IDF and having a task to use interrupt timer. The task is to generate a signal using GPIO pin. The signal should be on for 20ms and off for 6ms. Here is the code that I've tried. I don't know where I'm going wrong and please guide me if my understanding is wrong.
C:
#include <stdio.h>
#include "esp_timer.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "esp_log.h"
#include "driver/gpio.h"
void timer_callback(void *param)
static bool on;
on = !on;
gpio_set_level(GPIO_NUM_2, on);
void app_main(void)
gpio_pad_select_gpio(GPIO_NUM_2);
gpio_set_direction(GPIO_NUM_2, GPIO_MODE_OUTPUT);
const esp_timer_create_args_t my_timer_args = {
.callback = &timer_callback,
.name = "a timer"};
esp_timer_handle_t timer_handler;
ESP_ERROR_CHECK(esp_timer_create(&my_timer_args, &timer_handler));
ESP_ERROR_CHECK(esp_timer_start_periodic(timer_handler, 20000));
ESP_ERROR_CHECK(esp_timer_stop_periodic(timer_handler, 6000));
while (true)
esp_timer_dump(stdout);
vTaskDelay(pdMS_TO_TICKS(1000));
