Timer for two Air conditioners
sachinkallely
Newbie level 3
Newbie level 3
hyderabad
I am doing a timer for two Ac s.
PIC used is PIC16F676
environment used is Mikro C
AC hase 5 phases:
1) both AC ON for specified time
2) one ac on other off for spacified time
3) step 1 repeat
4) step 2 repeat but ACs are alternated
5) loop repeats
In proteas the ports do not turn on. they just show grey color
code :
void main() {
  TRISC=0x00;
  PORTC=0;
  do
    PORTC=0b000011;
    Delay_ms(10000);
    PORTC=0b000010;
    Delay_ms(5000);
    PORTC=0b000011;
    Delay_ms(10000);
    PORTC=0b000001;
    Delay_ms(5000);
  }while(1);
photo attached
have you tried pullups to 3.3 or 5Volts so
Your LEDs are connected to RC4 and RC5 but you're trying to blink RC0 and RC1. Your delay is 10s and 5s, Isn't that too long for blinking LED?
void main() {
  TRISC=0x00;
  PORTC=0;
  do
    PORTC=0b000011;            // should be 0b00110000
    Delay_ms(10000);
    PORTC=0b000010;           // should be 0b00100000
    Delay_ms(5000);
    Delay_ms(10000);
    PORTC=0b000001;         // should be 0b00010000
    Delay_ms(5000);
  }while(1);
Allen
void main() {
  TRISC=0x00;
  PORTC=0;
  do
    Delay_ms(10000);
    Delay_ms(5000);
    Delay_ms(10000);
    Delay_ms(5000);
  }while(1);
Allen
Oh My mistake. Thank you. Actually the output is not an LED. It goes to a relay. I just put an LED for testing purposes.
Still not working :sad:
Change pullup resistors to 330Ω resistors and you logic indicator on the components should work.
See my sim attached.
And the codes I modified for MPLAB HiTech C to work.....
Plus my hex file in zip format
#include <htc.h>
#define _XTAL_FREQ 4000000 //USING 4 MHz CRYSTAL
void main() {
  TRISC=0x00;
  PORTC=0;
  do
    PORTC=0b00110000;  // both LED off
    __delay_ms(1000);       // delay 1s
    PORTC=0b00100000;  // LED1 on LED2 off
    __delay_ms(500);         //delay 0.5s
    __delay_ms(1000);
    PORTC=0b00010000;  // LED1 off  LED2 on
    __delay_ms(500);
  }while(1);
Allen
  • 16f676 blinker.rar
AC hase 5 phases:
3) step 1 repeat
5) loop repeats
code :
void main() {
  TRISC=0x00;
  PORTC=0;
  do
    PORTC=0b000011;
    Delay_ms(10000);
    PORTC=0b000010;
    Delay_ms(5000);
    PORTC=0b000011;
    Delay_ms(10000);
    PORTC=0b000001;
    Delay_ms(5000);
  }while(1);
photo attached
You don't have MCLR pulled up and we don't know if you disabled that in the configuration settings. My guess is that's the issue. Also, change the pull-ups to an 'analog model' such as 'RES' (remember to change the resistance) or 'MINRES330R' for example.
Hope this helps.
Tahmid.
