Choosing the proper time scale is very important. It will not only impact the correctness of your simulation, but also the time it takes for your simulation. Let's take an example. If your entire design consist of a single file and it only have the following logic:
always @(posedge clk) begin
if (!rst_l)
cpu_interrupt <= #1 1'b0;
else
cpu_interrupt <= #1 s2m_interrupt;
end
Then your timescale can be 1ns/1ns.
But if the code is like this:
if (!rst_l)
cpu_interrupt <= #1.5 1'b0;
else
cpu_interrupt <= #1.5 s2m_interrupt;
Then your timescale need to be 1ns/100ps.
For both examples, you can have even finer timescale (e.g. 1ns/1ps) and your simulation will still work but it will unnecessarily slow down your simulation.
- Hung
