ktko
Newbie level 2
This is for a product design class, and I have very little electrical knowledge. My design is a trash can which locks when it is tipped over (or tipped to a certain degree). The lock would be simple, likely some kind of cylinder (or pair of cylinders) that would block the lid flaps from opening.
I was thinking of some kind of tilt sensor.
So my question is: if I want the cylinders to move once the tilt sensor reaches a certain degree, how would I do that?
The cylinders would likely be recessed into the housing of the trashcan lid. Not sure about the placement.
I don't need to actually build this product, but I want to at least understand how the electrical components work, or what i would need in order to make it work
Also....I've read that tilt sensors need to be run on AC current, are there any that can be run on some kind of battery? Or is there any way to get an AC current without having to plug it into the wall?
Any input is appreciated!
Thanks!
Thanks!
