Winsu
Full Member level 3
Hi All,
I have a connector which is screwless. It specifies stripping length of wires to be connected but, it doesn't specify if the wires must be tinned or not ( I mean just the tip). From my point of view if the connector is screwless a user would have to apply a bit of pressure to insert inside the wire, so tinning the wire will help to process. Does it make sense?. There are other variables that I should consider. The connector is inside of a sealed case, so environment is not an issue ( I have read that environment conditions can affect more negative to tinned wire than not tinned....not sure if i can believe this).
Thanks
Thanks
