TI064 troubles
ee101sg
Newbie
Newbie level 2
Hi, I am trying to use a simple non-inverting opamp configuration to bump a 5V pulse at 10Hz to 10-20V. I hooked up the output of a digital pin of an arduino to at TI064, and used +/-15V for the supply rails. I am consistently getting a larger output (typically ~5V) more than expected (tried adjusting the resistor values a few times). What am I missing?
We can see the input pulse is 0V / 5V.
Now please write clearly what output levels you expect.
Klaus
Btw...
* rather interesting "double inverted" positive power supply connection..
* missing R2
* ambiguous OPAMP type
Sim :
Notice the limitations of the output swing, above from spec sheet.
What is the G of the opamp circuit ? See following :
So what would the output want to be but cannot because your G is too high and is driving the
output into the rails. So the output transistor, Q14, in this case, saturates and cannot provide anymore
voltage to its output and or a load connected to output. The below OpAmp internal circuits are
"typical" for this example.
The OP2177 is still a very active part :
Regards, Dana.
LaTeX Commands Quick-Menu:
