davorin
Advanced Member level 3
- Joined
- Jun 7, 2003
- Messages
- 901
- Helped
- 11
- Reputation
- 22
- Reaction score
- 4
- Trophy points
- 1,298
- Location
- Switzerland
- Activity points
- 7,349
ti tps222x
Anybody used the PCI1520 (or PCI1510) chip in his design?
According to the datasheet the clock for the pwoer switch chip is coming from external. But also the according TPS222X power switch has the clock as input...
The datasheet says:
So how do I tell the PCI1520 chip to supply the clock for the TPS222X chip then without programming? EEPROM is empty and PC BIOS has no option to set it (o;
The datasheet says:
Bit 27 (P2CCLK) in the system control register can be set by the platform BIOS or the serial EEPROM to enable the PCI1520 to generate and drive the clock internally from the PCI clock.
