cupoftea
Advanced Member level 6
A certain big European Electronics distributor, who i believe , possibly has associations with Nexperia and Vishay, are currently doing the rounds, and saying that soon, all through hole Power MOSFETs for eg SMPS will be obsolete....and that SMD FETs will prevail.
On thread #24 of the following...
..we have one of the world's best SMPS engineers saying that...
"SMT & heat dissipation - always problematical ...."
So, will all PTH MOSFETs for SMPS soon be obsolete, or not?
Synchronous Buck Converter FET selection
Unless you have a 200MHz scope and high quality scope probes - you may not see the true rise and fall times - have you calibrated your probes? - via the 5V square wave on the scope Fet temp rise is very heatsink dependent - and air flow dependent - 60-65 C on the fets is usually...
www.edaboard.com
